Hi,
My Dutch isn't so good, so hope English is ok.
Boiler model: Nefit Topline - manual from 2007, so assume it's a specific model from around then
Issue is as follow -
Thanks,
Nick
- Yesterday, the hot water stopped working - ran the taps both upstairs and downstairs and boiler didn't kick into action. Same when trying to turn on the radiators
- Boiler display panel was on and responding, showing low pressure of 0.5 bar (not uncommon, we often have low pressure issues)
- Usually, I'd reset the boiler, but the reset button now fails to work - small change in the light on the display when pressed, but nothing actually happened
- Tried unplugging from power and restarting but no success
- Topped pressure up to 1.0 bar and tried again, but no success - boiler is on, but temperature displaying just above room temperature (28/29 degrees) and no sound of gas being burnt/hot water heated
- Our standard handyman came round, topped up pressure to 2.0 using a special pump and tried various things with the control panel, but had no success. Reset is still not working after 20/30 tries,
- Is a broken circuit board/control panel likely to be the problem? Any other guesses as to what the probem might be?
- Is it possible to replace the circuit board on a model this old? Roughly how much would it likely cost?
- If it is possible, do you think it would be worth doing this or just replace the whole boiler anyway?
Thanks,
Nick
