Remeha Tzerra Ace 24C
Hello,
I am having an issue with a Remeha Tzerra Ace 24C.
It starts up; I can hear the flame burning, but then it heats up over 90°, and I immediately get an error code of H01 05. It feels like it burns unnecessarily aggressively and powerfully.
Then I changed the associated sensors, and it worked for four days before the issue returned.
I researched the code and checked everything the manual required:
- The water pump is working fine.
- There is adequate pressure.
- I cleaned the heat exchanger.
- I have changed the sensors (both the upper and lower).
- I have changed the motherboard.
Can some of you kind people help me solve this?
I made a short video of the heater:
  • Waarschuwing
    Klusidee
    Waarschuwing
  • it looks like the boiler is burning for hot water, the command come from the flowsensor with a little printer circuit bord.
    If you cleaned out the heat exchanger the gasked should be replaced, in the netherlands its not allowed to service your own boiler, i recommend you to call a specialist to service the boiler.
