No problem.
I would advice not to cut those pipes. You would need special tools to close them of.
You will need te turn off the main valves (there should be 2)
Then you will need to take the pressure of and drain (part of) the system.
Remove the radiator at the radiator valve, remove the valve and put a cap on the pipe. (also at the bottom one)
Depending on the system you wil need to refill, open the main valves, get the air out of the systeem and maybe more.
In apartment buildings working on the heating system can be tricky.
My English isn't perfect, so if something sounds wierd, I probably used a wrong word.
Can you read Dutch?
